Yes, but what I’d like is text from the graph below instead which is our actual reflection strength that we could write into a gradient. The numbers that you’ve downloaded could probably be used too but I’d need to find out the equation to change those numbers into the curve below to get something directly useable. Nothing back from Mikhail yet but I’ve got a while to figure things out on it. Having the equation makes more sense since otherwise we’d be limited to the range of metals given on the site.
