point position pass
Is it possible to render a point position pass in vray to use in conjunction with a normals pass in nuke to relight an object?
Chris
Yes, just use a VRayExtraTex element connected to the position output of a SamplerInfo texture.
would that be the pointObj output fro msamplerInfo into the vray_texture_extratex r,g,b ?
doesnt seem to be a position output.
You need the “pointWorld” output of the samplerInfo connected to the “vray_texture_extratex” input of the render element.
ok,thanks. seems to work.
Is there a way to save custom render elements?
You mean save it as a preset? Or you mean the output image?
yes, as a preset.
