Hey.
Attached is my result and the result I would like to receive. can not do it:rage:.
This is a wall made of polycarbonate panels
Does anyone have an idea how to get the desired result?
I would be very happy to get help.
I could be wrong but It seems that your reference has some kind of frosted glass not policarbonate but maibe you need to change the tiles distance, I found this project with more references maibe this could help
Thanks Carlos.
The architect drives me crazy ![]()
He wants polycarbonate like in the picture I attached, which will be dark and almost not transparent
And I can’t get the result
The final product must be images or animation?
In the first case, before request make you mad, did you evaluate to “paint” the final effect with a texture that simulate that kind of refraction? Or make some masks to make some post production in Photoshop?
It seems that you’ll never reach a similar effect in a realistic way as the buildings are completely different.
The attached image you posted show that behind those panels, there are large rooms painted as white…in your building seems that you have that panels as cover for the facade. So, if is like it seems to me, it will be impossibile to get it without faking.
Well, the final result seems fine.. I’m not sure that everyone will see polycarbonate but you’re constrained bby the building design…so i don’t think you could do better than this.
I hope your architect is happy!
