Hi guys, today I confronted a new problem and till now I don’t know the origin of it or how to solve it. When I’m starting interactive the nb. of polys and verts is changing drastically, from 8mil to 62, how is posiible and could be solved?
Thank you!
Hi. Are you using displacement?
Yes, exactly on that mosaic
Then that’s the reason. If you turn off displacement, there should be no changes in the numbers.
You are right, works. Thank you!
