hi guys
We try to create simple scene, same environment with two light configurations
we had some problems with displacement on the wall testing new version in 1.2
but the result is good
edit: removed advert link
I like that curtain material, would you like to share the recepie? Im always strugling with those.
hi
its simple
plays with a map in opacity and translucent..
try to give a bit of opacity and translucent
Hi, what problems with displacement did you have?
i think the bricks don’t look like bricks in terms of displacement, a little less would be better as mortar usually slightly curves toward the edge of the brick
I’m not realize… can you explain better " slightly curves toward the edge of the brick" ??
if you observe a real brick wall, the mortar is never smooth and straight, and weaves in and out at different places, it is often as random as the bricks themselves in terms of position. Your flat mortar gives away the entire wall making it look unrealistic.
