Pool amenities problem
I have a sphere around my site and a ground plane for the grass. Without it the site is way too bright to even see anything…I can still not get these settings right I guess…Arrrghh Anyway…I turn the sun around and I get that weird green sky thing in the background…any thoughts
Hi. You should try excluding the sphere from the sun’s illumination, then uncheck the “cast shadows” option in the object properties and, finally, you should make the material for the sphere self-illuminated. You should also change it’s vray object properties so the sphere doesn’t generate or receive GI.
Jorge
Hey Eric.. back again :slight_smile:
hehehe
What are you using the sphere for?
First of all I would suggest you hide the sphere and nail down your render settings. Then unhide the sphere and do what Jorge said.
Depending on what the sphere is used for there might be better options.
<off topic>
Oh yeah Eric, getting a 40" 1080p LCD tv delivered today for some hidef xbox360 action :slight_smile:
If you havnt already you gotta play Overlord and The Darkness :wink:
(comment off topic->>)
40"???
Bastard :stuck_out_tongue:
(off topic reply)
hehe yeah… given my 30" LCD monitor was bigger than my old TV thought I should upgrade the TV :slight_smile:
40" is about the right size for the small area it will be used in.
oh.. and Mr Bastard, if you dont mind :lol:
Cool…I shall try all and some of that…So the Sphere should not affect the scene at all correct?? This would be much quicker if every time I relinked the dwg file I did not have to reapply all my modifiers and maps…LOL…
40"…Daddy likes…Yes…I have played both of those…And (off-topic) again…You need to check out the Splinter Cell and Metal Gear videos…NICE!!!
OH excuse moi…how rude OF COURSE MR.
Have fun!! :lol:
my mate is using the 40" now for games.. its just massive.. hahaha.
Eric, I will check out those vids.
oh…well…I was using the sphere for the background…Should I do it another way??
Hi Eric. Why not put the background in the environment slot? If using LWF and vrayphyscam I find that I have to crank up the output to about 160 (same as my shutter speed) in the material editor. If using a sphere you’ll have to exclude from all lights and GI.
Yeah if you were just using the sphere for your BG then I might well be better to stick it in the max ENV slot, and as long as you have the vray skylight override on it (the BG) wont cast any light into your scene.
So I can just drag my bitmap into the MAX environment slot and it will look fine?
Ok…I drug the bitmap into the slot and the background is black? What next
Did you crack up the output-amount for the bitmap as mentioned by powerandrubber?
oops…I left the decimal in and it was 1.6. DOH…Ok…Now…What should my Vray Dialog Environment be set to? Right now the GI ENVIRONMENT (skylight) override is NOT checked.
If you dont turn it on then the GI will be coming from your max env slot.
Best to turn it on and put a vray sky or something in it. Or just use the color.
