Pool Water
Hi, can someone tell me how to make 50 cm pool water? You should see the bottom but get some reflection with small amount of bump.. I was able to make it in older versions but now i am not..
Hello @kenancakir ,
Take a look at this article here: How to create Refractive Caustics in V-Ray for SketchUp.
It focuses on Caustics in order to achieve realistic results , but also provides an instruction on how to create a water material. Article contains downloadable scene that you can use for reference.
Hope it helps!
Thank you..
