The UI of Corona materials is slow to display, especially when using IR and switching between materials. The UI will redraw only slowly, due to the fact that Corona materials and the render dialog use the Win32 framework for its UI.
It’s well visible when compared to e.g. Autodesk Material, which uses Qt as the UI framework.
Please port Corona’s UI code to Qt so the UI is fast to work with.
Submitted on AHA Ideas (CMAX-I-23).
Also see slow UI discussion, which may or may not be resolved by a Qt rewrite, https://forum.corona-renderer.com/index.php?topic=43406.0
Submitted on AHA Ideas.
moved to jira https://jira-chaos.atlassian.net/browse/CMAX-1304
Submitted on AHA Ideas by Marcin Miodek.
I’m surprised this doesn’t have 1000 votes. I don’t fancy vray, but wow the reworked material UI is blazing fast, pure joy to work with whereas corona sadly is the complete oppsite in this regard.
Submitted on AHA Ideas by Johannes Lindqvist.
CoronaPhysicalMtl and Corona Image Editor have been rewritten to Qt in August 22nd preview build. (https://forum.corona-renderer.com/index.php?topic=45313.msg235216#msg235216)
Submitted on AHA Ideas by Aram Avetisyan.
As of Corona 14 (released 12-Nov-2025) following materials and maps are rewritten to Qt:
- CoronaPhysicalMtl
- CoronaLayeredMtl
- CoronaVolumeMtl
- CoronaHairMtl
- CoronaSlicerMtl
- CoronaBitmap
- CoronaColor map
- Corona Image Editor
thank you Team!
much appreciated.
Submitted on AHA Ideas by Marcin Piotrowski.
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
