Hi
I used portal light for first time but for some reason when I created it again it does not seem to function with HDRI.
As alone it works ok but with HDRI it is a bit of quesswork.
have you disabled “Occlude other lights” option?
Can you explain what exactly you did? There is no such thing as “portal lights” in Corona.
Assuming he means portal material.
I think we all understood what he meant. Are they even recommended when using HDRi’s? I know I have been told they are not recommended for use in Vray.
Hi! Can you maybe try to create a simple scene and post it here? We could then test it and see what is (or isn’t) wrong there.
Hi guys. Thanks for replies. I guess I got it already fixed with latest update.
I just moved and have only Internet connection at my workplace
so cannot post personal corona project files atm.
See you later.
