Do not know this is a bug or a feature …
Portals reduce translucency effect from CoronaSky or HDRI!
Try it with max sample intensity 0
So the image looks different with MSI 0 and no portals? Do you use HD cache?
yes, there is supposed to be a difference between different MSI, but not between portals/no portals when rendering in unbiased mode (MSI 0, PT+PT)
You mean with MSI=10 samples are clamped? Setting MSI to 0 should introduce more noise, right?
I tested it too, the difference between the portals/no portals - no!
Yes and Yes!
no, 0 = infinity = no bias.
If there is no difference when using PT+PT MSI0, then it is not a bug, but I’ll have to set default MSI higher in future builds
And you can restore to default random sampler “Aplha 3 emu..” :)! According to my tests, it is better for light sampling.
