Posibility to rotate VFB.
Hi, from time to time we run into situation where for the framing purposes we rotate the camera by 90 degrees to have a vertical render without changing the original (horizontal resolution, used for the rest of the frames).
While working on this specific, vertical frame the VFB is obviously rotated. As you can imagine working in IPR or whatever can be painful after some time, it literally causes the neck pain haha.
Is there any chance to have a feature that rotates your VFB view by 90 degrees?
kindest regards,
Karol
You mean rotate just the image in the VFB, right? Not the window itself :smile:
Just the image, yes :stuck_out_tongue:
Hi, is there any progress on this matter? Is it difficult to implement?
No progress for the moment.
Question, though - will it be enough to be able to rotate by 90 degrees only?
I guess yes :slight_smile: Thanks yolov.
