possibility specular and diffuse separating in Corona lights
is it possible to separate specular and diffuse lighting in Corona lights, especially in Corona Sun, for cleaner results with DOF and Motion blur effects in render with reflective materials.
for example: in some scenes with DOF effect no matter how many passes I will be rendered, a noise on speculars and highlights still remains, especially with exterior close-ups on a plants and other thick objects/Options of -/max Sample Intensity/ don’t help in this case, only if change the value of 1 or 2 - that is not a valid.
option -/Light Samples Multiplier affects only on Diffuse Direct Lighting, not specular//Also is no matter a property of glossiness of material itself/
I could never get a clean result in this case/
it would also be nice to do check box for overall ability to disable or enable refraction and reflection effects/
Duplicate: possibility specular and diffuse separating in Corona lights - Corona for 3ds Max :: Requests - Chaos Forum
