possible bug in render region
OK I used the render region in the VFB but then turned it off when coming to render out sequence of light maps.
I get the client to render out the maps via vrscene file but it only renders out the render region and not full size.
I went back to the main scene and rendered out at full size double checking that the teapot was turned off and re saved the vrscene, again on the client it still rendered a region and not full resolution.
I have rendered out from maya as a work around…time is pressing!
OK every time I create a vrscene it only renders a region but if I render from Maya it renders full size. Render Region is not ON!
A known bug/pain in tha a.. that we found several months ago.
Use the imgwidth, imgHeight and region and crop flag in the batchrender command for the vrscene. That should help.
Did you try that with the latest V-Ray 1.50.SP1?
Using latest nighly build and still getting this issue and this is a new scene 2 months down the line…anyone else still getting this?
Fixed it, you have to “reset region marquee” in the MFB.
