setup:
multiframe incremental or incremental add to current map
10 dr render stations
rendering localy or through bb
complex scene or a simple scene with a bunch of teapots
nth - every 10 frames
don’t render final
vray animated camera or just a still perspective view
the first several frames render out successfully, but after 3-6 frames the render stations stop working.
Does anyone have any ideas why this may be happening or how i can go about solving it?
none of them are? I’m pretty sure i used to do this in the prior version.
Assuming so, what is the suggested work flow for the following situation.
• Only every 10 or 30 frames are needed to generate the vrmap
• I have 40 computers available
• I have two individual license of vray
• I have an animation that is 2000 frames long
In the past i would have:
1) used DR with multiframe inc to generate 1 vrmap
2) then use that vrmap to generate each frame through backburner (no DR).
It seems that now I will need to:
1) Generate individual vrmaps (every 10 or 30 frames) via backburner (no DR)
2) Create a script that combines together these vrmaps (via irradiance map viewer). I have gotten this to kind of work
2) then launch that script via maxscript from bb job that is dependant on the individual vrmaps being done.
Just use multiframe incremental with DR unchecked rendering every 20 frames or so depending on your scene and camera path. Since after the first frame it’s only calc’ing the changes to the map it’ll actually go quite quickly. If you’re using LC as your secondary set it to flythrough and change the subdivisions to account for the increase in visible area from the moving camera (I usually change to world scale rather than screen but this will depend on your scene).
Once this is done point the irrad. map to the saved vrmap and render your frames using BB and no DR.
Hard to say what a good LC number is but I’d guess soewhere in the 1500-2000 range. I never really understood what a good number is for this or how to determine it although you’ll start to notice it if it’s too low. Maybe someone else???
Correct about saving the LC. Set to autosave and switch to save map.
I haven’t tried it but you should be able to start the first job as a BB job but only set it to use 1 machine. The dependent job should be fine as well as long as you set the “from file” names to the correct names (and use only UNC drive paths).
