Possible Bug
Hi guys I’m using 1.47.03 with Viz 4 and I’m finding that in the qmc sampler dialogue box the noise threshold will not go below 0.1 if I use the spinner or 0.01 if i type it in. The value used to go to 0.005 and I’ve also seen it that low on other peoples screen grabs. Any body else using viz4 having this problem or is it just me ?
Cheers
TD
Hi!
You may try to set the spinner precision decimals to 3. Preference Settings → General → Spinners. I had the same problem with one of my workstations.
Mare
Thanks Mare you hit the nail on the head, the spinner tolerance was set to 2. I’m in a world of happyness again.
Cheers
TD
