Possible Glitch in v7 January 22 Build
I started using the latest daily build and noticed something wrong. I’ve setup a simple scene with a shadow catcher to use as an environment as I add Corona materials to my 3D cars. All of a sudden, the Sky Object is rendering when I’ve set it to NOT be seen by Camera. I know this because the Background Object no longer renders at all, thus revealing the HDR in the background. I’ll be uploading a scene after I post this.
As you can see in my image here, the render in the top-right is correct. The image in the bottom-right is the exact same scene with no changes, but rendered with daily build January 22.
A simple workaround is I put a curved studio object (floor that curves up behind my objects) and applied my shadow catcher material. This renders as expected.
Build timestamp: Jan 22 2021 18:59:59
Version: 7.0 daily Jan 22 2021
Cinema version: R20.059 CINEMA 4D Studio
I don’t know if my scene uploaded or not. It’s 168 MB so it should work. It just sits there for a couple minutes, then the Captcha says I need to click the box again. Confusing. Would be nice to see a progress bar with the regular uploader.
Hi, It doesn’t look like it worked. can you please try uploading it again and also let us know the file name when done?
Used the Dropbox link instead.
“Corvette Collected.zip”
We confirm this behaviour (happens only on Mac, apparently) and will look into it.
(Internal ID=632210137)
Thank you,
Jan
