I’ve recently installed extension 1 for max9 32bit. I’ve noticed just 2 odd/bad things.
1. if I detach a polygon from an editable poly, and in the dialoge box that pops up promting for a name, I name it for example “front door” then select my new object that I named front door, but it did not finish the whole name!? Instead it is called “fro” or “f” or “front d”
Not a big deal, but it never used to do this…and it’s kind of annoying to name an object twice…
Anyone else experience this? :?
Also, now max seems to crash sometimes when using the standard UNDO. Not a hang or messy freezing, it just vanishes in a split second. Seems to have just started since adding the extension1…maybe that was bad idea?
thanks
