Possible to measure distances in a photo?
Typically I’m doing modeling from cad, elevations, etc with dimensions. In this case I need to build a space in 3d from photos. Is there a way to measure a distance if you don’t know a single measurement? I know this sounds like a rookie question from someone who’s done archviz for a while, but I’ve honestly never had the need (or I’ve always had the dimensions).
Attached is an example of what I’m working with. Thanks in advance…
If you know one dimension you can use SketchUp.
Assume the seat cushions are 425-450mm off the floor. from that you can figure out the height of the wood trim / ceiling, wall width etc.
