Nightly builds from tomorrow will contain Python “Post Translate” support (ROP → “Post Translate”).
It’s similar to https://docs.chaosgroup.com/display/…ed+V-Ray+Scene, but is based on AppSDK Python binding.
WARNING: AppSDK Python binding gives you FULL control over the rendering process so be very careful.
I’ve added some restriction in VRayRenderer() object creation, but still a lot of methods are available.
I’ll try to limit methods available for “post translate” in the future.
Check some docs about AppSDK:
* Application SDK
* https://docs.chaosgroup.com/vray_app…n27/index.html
Some simple examples:
List scene plugins:
import os
import vray
from vfh import vfh_utils
with vray.VRayRenderer() as renderer:
for plugin in renderer.plugins:
vfh_utils.logInfo('plugin ' + plugin.getName() + ' (class ' + plugin.getType() + '):\n')
Change color:
import vray
r = vray.VRayRenderer()
p = r.plugins["|mat|vrayMaterialBuilder|vrayMtl"]
p.diffuse = vray.AColor(0, 1, 1, 1)
If you are not using installer you may have to modify your .json or .env to include path to AppSDK Python binding.
For json it may look like that:
{ "PYTHONPATH" : "${INSTALL_ROOT}/appsdk/python27" },
