Post your Grass renders.
Hi guys, thought it be cool to post your best grass renders to compare with others as no 2 grass renders are the same..
heres mine,
my settings:
Use any image as a diffuse layer using default bitmap settings.
Add a Displacement layer change from 1 to 3..click the m and add a new TexNoise layer..all defaults except the following:
Size 0.025
Frequency Ration 2.0
Max Ratio 0.5
Re: Post your Grass renders.
cool topic, i’ll post some of my images, eventhough they are a little bit old :stuck_out_tongue:
look forward to seeing them
very very good thread. to push it further perhaps also place your settings.
Updated my first post with my settings..
Come on guys lets see your grass :wink:
Hi, this is a test I made once.
It was made with fur pluggin for sketchup. I had to install the mem_patch for sketchup because the file was too big.
Fur settings:
You have to repeat the process and play with the direction and force values until the terrain is full with grass.
nice grass…care to post your fur settings?
i thought i had more images, but this was everything i could find, just old images :stuck_out_tongue:
