PPM Caustic Test
This is my PPM Caustic Test.
Inspired by this (Renderer for architectural visualization - Corona | Chaos)
Sad, that at the moment it isn’t support dispersia and dont get color from absobtion.
wow !! footsteps of rays :smiley:
This is so beautiful !
How one achieves such an effect ?
This is ortographic top projection of this scene. (i don’t know how insert image from attachment in middle of post)
There is thin light source (full direct), that create a light beam. This emitter is tilted slightly down and create light path on floor by deflecting from colored mirror walls.
(Sorry if my english not well :frowning: )
Nice. I never knew how it’s done!
Thx.
I think that image from gallery, was made a little differently. But i don’t know exactly how.
Is it long to render ?
Because a rotation of the central prism would give a quite mesmerizing animation !! :smiley:
light tracing should work better for this kind of scene
About 15 hours.
I have pretty slow processor for Corona. Look at the render stamp.
I will try.
But before i tried all engines for caustic, and only vcm and ppm give me a normal result. May be i do something wrong?
I tried and lighttracer is working in this scene. What limitation of this engine?
It does not work for glossy objects
As far as i understand PPM work with glossy dielectrics now very well to?
I planning make another image (not technical) and still dont know which engine i should use.
yep, it also works pretty bad. It can be improved to work reasonably well, but there is no point, since BDPT/VCM is so much better anyway.
Tell me about this VCM. It have limitations or some things / settings that I should know?
