When i render with PPM active, c4d (r18) crashes
Hi there, one must take caution when playing around in the dev-debug/experimental settings for this very reason. By default we have this set to disable to try and avoid situations like this. Can you also share the settings you were changing?
My friend test the same scene with 3ds max and it doesn’t crash. It could be a bug on c4d?
That’s hard to say, if we had your settings we could try and reproduce it. Only then I could tell you. ![]()
Thanks!
