REQUEST I think your users would greatly benefit from a PRE-LAYOUT Grid/Window as one goes into VERA from Enscape - Because of the SQUARE FORMAT it is VERY Tricky to “get the layout right” and many “False Starts” are wasted in proper framing…….while with a “grid”…..it would be seamless - Thank you for considering this!.
Submitted on AHA Ideas by David Sargert (ENSCAPE-I-1661).
Just to better understand your feedback - when you mention entering “VERA from Enscape,” are you referring to our Enscape-Veras integration for exporting views, or are you talking about a VR experience directly within Enscape, or a grid when creating the visual presets?
We want to make sure we understand your workflow correctly so we can assess how a pre-layout grid might help.
Whoops sorry my goof with the name - I am referring to the Enscape-Veras integration button. The challenge which creates “wasted trys”. Is the fact that the VERAS creates SQUARE Outputs while most of us use rectangular screens - my suggestion is a simple “pre-framing square” that woud allow users to define the actual “framing” that will be the result of the output from VERAS - Is this making sense? Thank you for all you do for us - Its become a powerful tool !!
I think it would make the most sense if the output size that is defined in Enscape Visual Settings > Output was copied upon export. Now that is what I manually type in for the size of the render, so I know for sure it’s the same size.
Submitted on AHA Ideas by Martha Dijkstra-Maatkamp.
