Pre Purchase Issues
Hi, We can’t seem to be able to create the .WBC file needed for the reprogramming (and validation of ownership for the actual ordering)
The Desktop Right-click > New - don’t show any wibu options and accessing the server via http is missing the “To upgrade your licenses, click here.” Link… so we can’t create the .WBC file
What might be the problem?
thanks
In order to use the link from the license server, you need to have V-Ray RT installed first. If you don’t have that, you can email me to vlado@chaosgroup.com and I can send the updated license server separately.
Otherwise, you can manually create a .rtc file (which is the same as .wbc) directly from the WIBU-KEY applet in the Control Panel, but this is more complicated.
Do we need to install any another version of RT to be able to get the final licence? Or the demo version will work as final?
I’m quite lost here…
The limits of the demo are hard-coded; like with the standard version of V-Ray, you will need to install the proper full build.
So how should I get it?
Gonçalo
Check your email, I replied to your question there.
Vlado, You can check your email now.
Thank you
