pre-render script vs. Vray
I have a pre-renderscript which just set another save path for IRRmap
renderers.production.adv_irradmap_autoSaveFileName = “X:\\maxtest\\muh.vrmp” as string
in vray RC3 I get error
Saving irradiance map to file "¼╞╓§8▌X♫st\test.vrmap
is there a work around Vlado ?
I know RC3 is very out of date but I must run it beside all the other RC and SP release to be “compartible” to my clients
a.
Is it possible to UNC the path rather than using a drive letter?
If I remember correctly you need to format it like this:
\\\servername\\folder\\file.vrmap
Not sure if that will help you.
Some help for your scripting.
at first, when you build a string with " .. " there is no need to parse it to string.
as string
If you using slashes => \ you have to escape everyone, so unc path will be
“\\\\server\\folder\\file.vrmap”
when using backslashes => / you dont hav to escape, so unc path will be
“//server/folder/file.vrmap”
Both give same result.
