Precise Embree option
Any reason why you would check these (on by default), I see no difference on multiple tests, including animation.
Why not have free 70k ray/s / faster render?
Free powa :smiley:
No, just curious to know, when the precision is needed.
render interior lit by enviro light with high-poly one-sided geometry curtains in windows and you will see ;
it helps with this kind of small light leaks. 70k rays/s will save you few minutes… but if you ever run into this problem, you will lose hours. So it is on as an insurance :wink:
I would put it in more prominent tab and announce its meaning, but then the internet would be full of “100% universal settings” guides telling people to turn it off as a first thing in new scene. And then there would be bug reports from clue-less people about light leaks :wink:
Ye, found light leak in translucent materials, this is fixed by the precise flag.
I’m still curious though what “high quality” means. If it’s no trouble I’d love to know…
it enables the “precise” flag in embree. That causes embree to use slower ray-triangle intersection algorithm, that is watertight (does not let any rays through on boundaries).
I think you mentioned you study IT, so you probably know about problems with float imprecision. The fastest ray-triangle intersection method (moller-trumbore) suffers from some catastrophic cancellations in some cases - it calculates the volume of tetrahedrons created from ray origin, intersection point, and 2 points of the triangle. This volume is zero on edges, because all 4 points lie in single plane. This zero will easily ruin your day, because you need to invert it.
thx^^
ye, I study computer-science
