Preparing camera sampling need much time
at the moment I have a problem: if I start a rendering, than it hang a long time and the progress window show “preparing camera sampler”. Most it start after a while, but at my current file it dosn’t start to render. Any suggestions?
Thanks,
Micha
Re: Preparing camera sampling need much time
Hello Micha,
I had the same problem last Friday,turned out it was a bad object in the drawing.Try analyzing your drawing.In my case it was a mesh object that a customer of mine,exported from sketch-up.I could not even explode it.
Renee
I found some bad objects, but for a test I hide the objects and it dosn’t help. I start again with the scene and it works (with the bad objects from the client).
How did you get it working?
I deleted it and re did it my self .
If you turn the layer off,does it do the same thing ?
