Preparing geometry sometimes take 3 minutes to complete, sometimes it take 3 seconds even though nothing in the scene has changed. Why is this? How can i lower the amount of time that the render is locked to this prerender thingy?
Forest pack in some scenes, but not in another. I am actually on Max 2017
Is noone else having a problem with this? Its very frustrating not being able to make a “quick preview render” without having to wait for the “Preparing geometry” to grind for almost 3 minutes
Are you using displacement in your scenes?
I’ve had this happen seemingly randomly in the past and solved the issue by merging my scene into a new file. Maybe give that a try?
if i’m not wrong, I remember there was a thread here that completing windows update could solve this issue.
So, i’ve tried scenes at my office, i work on a i7 5960 there and it works just fine. Render starts in a few seconds.
At home, at my 2xXeon 2650, the phase takes about 2-3 minutes. Same scene… So i suppose it comes down to this station. I’ve done all the windows updates, updated drivers in general, nothing works.
Also, interactive mode starts up in a few seconds, so no problem there.
Any more suggestions?
you could capture a minidump during the parsing, I can then take a look at it (see my signature)
Thank you Ondra. I’ve upploaded a .dmp at dropbox. ![]()
note to self: filename is
Daniel Åström - 3dsmax.zip
Yeah, sorry, should have specified i suppose
no problem ![]()
Hi, just checking in, when could i expect a verdict?
Can’t really start up projects with Corona when this persists, so if you have any idea to what action i need to take, do tell ![]()
hi,
one weird thing is that AcIPC_2_x64 tries to read some file in 4 threads. It looks like some bridge to autocad. You could try if removing it solves the issue.
Other than that it looks like VFB refresh issue, which is scheduled to be fixed in hotfix. Can you try increasing VFB refresh interval, or zooming out, to see if it helps?
Finally I got a solution for this “preparing geometry” delay. In my case it was a corona decal, that had objects excluded, instead of objects included, I hope this works for somebody.
Any chance of a copy of that scene? Via ticket is fine for privacy, Chaos
Failing that, can we have a fairly detailed description of what was going on? Did the Decal overlap 10s or 100s of objects, and it was accidentally excluding the two it should apply to and so was being calculated for 10s or 100s of objects? And on reversing that, so including those two, it was only being applied to two? What happens with no include / exclude where it just applies to all objects it overlaps, is that fast or slow?
Thanks!
Tom
