presenZ VR quality and maximum render resolution
hello,
why is the render resolution of the vray-presenZ rendering limited to 5750 pixel?
i just rendered a test image with 4000x2000 pixels and the quality was not that good. see the gap between the sofas.it look quite transparent there
it seems that there are some “pointclouds” missing. i want to render it next days in maximum resolution and see if it gets much better.
any ideas? thanks
thomes
so i did a new rendering with maximum resolution of 5970.
i think that i do something wrong. quality is still not good… if you look at one of the first prerendered scenes from presenZ ( i attached here ) the overall detail and renderquality looked much much better than for example the new prerendered architectural scenes presenz offers within their latest Architecture_Demo content …?!?
maybe somone from vray knows help.
thanks !
Have you contacted Presenz support?
yes, today
update:
Thanks for your interest in PresenZ, and apologies for your bad results.
We are aware of issues with small spaces which creates some holes. We already came up with a solution in the new version, which is not released yet, but I can provide you an installer.
The new version will require your save path in the frame buffer to end with .prz ie: C:\Users\Name\PresenZ_Render_v01.prz
You will receive a google drive link.
In addition the resolution of 5790 is not going to give you a much better results than something like 4000x2000, I personally never go over 5000x2500. It’s better to increase the bucket samples to get a better image quality.
Don’t hesitate to contact me if you have any questions or issues with the new plugin.
Thanks for the info. So it wasn’t on V-Ray’s side after all.
thanks peter,
finally i dont yet understand how that engages with each other
