Presets makes life easier
Hi.
Can you add preset setting for white balance like V-Ray for 3ds max version? it’s more easier to get daylight or neutral white balance with presets in v-ray for 3ds max.
One trick I sometimes use is to render with material override on and sample a wall or a ceiling that is not hit by direct sunlight. I use these RGB values to set the whitepoint. But hopefully V-Ray Next for Sketchup is around the corner so it is automatically set!
Best,
Peter
Apologies for the confusion! The page is now edited. There are no presets in V-Ray 3 for SketchUp. The leftover misleading info has been copied directly from another V-Ray product page.
There is currently no plan to add any WB presets. V-Ray Next for SketchUp, however, will introduce Automatic Exposure and Automatic White Balance.
Kind regards,
Peter
Good to hear that it worked. And any ETA on Vray Next? :smiley:
Too early to say. First, there will be a beta which has not been announced yet. Once it concludes we will be able to provide more info on the official release.
Kind regards,
Peter
