Is there any way to prevent origRGB being saved with “Separate render channels”? I just need the sequence with the Lens Effects applied.
No, but here is a script with which you can. It saves only the EffectsResult channel:
fn SaveEffectsResultOnly =
startFrame = 0
endFrame = 50
for i = startFrame to endFrame do
slidertime = i
max quick render
outputImg = @"C:\Users\Alexander\Desktop\effects\" + i as string + ".exr"
vfbControl #setchannel (vfbControl #getchannel effectsresult)[1]
vfbControl #saveimage outputImg
try(SaveEffectsResultOnly())catch()
Set to render single images, open the script (Scripting>Open script), enter the start and end frame, replace the path and format and Evaluate All (Toolts>Evaluate all).
Thanks!
I’ll try it out.
