Preview versions Light issue
At first it appeared as though lights with IES Files were not rendering, however now it looks like some are and some aren’t. These wall lights are exactly the same and you will see 2 are on and the rest are off. Very odd.
Thank you for reporting. Does this happen on all quality levels? Also during movement or only at the final image?
As I move they turn on if I’m close to them, but if I move slightly away the ones beyond turn off. Its definately doing it at all Rendering levels, bascially as I 'move away from the light source they turn off. So only the fixtures I’m closes too are on. I’m happy to do a web meeting and show you live if you want, just email me at
Thank you so far. I think I can imagine what it looks like, but the constellation of the IES light etc is interesting and would be hard to figure out remotely. Could you please ensure that you have the current version (maybe even preview version, maybe the issue is already fixed), then cut a little cross section around the problematic area and send us an executable export so that we can check that in detail? That would help - thanks!
@sdbrownaia Take a look at the new preview version 2.1.3.1202
