Principle Shader > Vray Materal
THere is any converter for converting non-vray materials to Vray? I use Quixel Bridge, and there is only Principle Shader available when importing. When there is a lot of assets, it’s quite hard to remake them manually
There are no plans making anything like that.
We’ve working on MaterialX support and recent nightly builds contain new implementation.
May be you could find smth to convert principled to MaterialX and/or ask Quixel Bridge for MaterialX support.
Thanks! And when are you planning to add support for Hoydini 20?
Builds will appear in the nightlies right after the official release.
If you want to test it earlier you could request access through our support request form to the nightlies section with H20 builds (we have builds for 20.0.506).
Thanks! Just requested. But H20 already released, or it’s not official?
Then it’s time to add it to the regular nightlies :slight_smile:
Looking forward to it :slight_smile:
Hi @Mikhalenko ​,
V-Ray builds for Houdini 20 are officially published here: https://nightlies.chaos.com/main#/vray6houdini/stable/6.1/20231114
Enjoy!​
