Probem_light mix with diferent skys the volume coronasky dont change
hello,
light mix with diferent skys in multimaps, the volume effect coronasky dont change, its aply only one sky and dont change de volume for oher sky.
thanks
Only 1 atmospheric volumetric effect can be used at any given point in time even if you are using multiple sky maps.
If you explain a bit about, what are you trying to do and what results you are expecting, we can try to suggest a workaround accordingly.
i found one solution.
use the state sets for each camara and sky.
thanks
after all it doesn’t work.
I cant do it.
the state sets for each camara change but in frame buffer corona dont change, because de light mix dont update automatically, vray can do this.
I like vey much corona in terms of render but vray itis very powerfull compare to corona.
As far as I understand, what you are trying to do is, you want seperate Corona sky per camera and you would change camera, the corona sky would also change its volumetrics, right?
to simplify
If i change the color or intensity the direct overwide with colorcorrect , the volume effect of the sky don´t change.
Sometime for interior i want to keep the global ilumnation of the sky, and only change the view of sky to darker.
thanks
