Problem behind glass in GPU mode
here’s my problem.
A FloorGenerator floor behind glass. Ok in CPU Mode. Problem in GPU Mode.
Hard to say what’s going on without the scene. Simplify it and send it via the contact form.
Scene sent. (Request #362913)
Thanks for the provided scene. The darkening seems to be caused by VRayPlane001, which overlaps with the floor geometry. On top of that it has Trace Reflections/Refractions off, which pronounces it. It is visible in CPU too, but milder. I doubt you need this VRayPlane, so I suggest you either delete it or reenable its refl/refr tracing to fix the issue.
Thank you.
The VRay plane is the problem.
Why is it only a problem behind the glass?​
Because it had Visible in Reflections/Refractions off, which made the overlap visible.
