Hi guys im trying to make this kind of material but cant get it to work
Im actually trying to texture the same chair as the pic but due to its high poly count trying to use a diffuse texture is impossible. Any thoughts ?
Edit: Im using a diffuse texture and this is the problem
Re: Problem creating material
Not sure if this is the right solution, but could you try using a TexColor for the diffuse and then just put another diffuse color layer with a really really reflective layer above that?
make sure you smooth the geometry’s normals to help get rid of face edges
