369/5000
Hello, today while I was rendering a scene I finally realized this problem on the displacement map that was reflected in the mirror.
I tried with the search button but I did not find anything about it, it would seem that the part of texture that is not part of the PV has problems of display map displacement.
Someone knows how to solve, thank you.
Try to turn to world space displacement, it should fix the problem with offscreen areas not being displaced, at the expence of heavier RAM consumption.
Good morning, thanks romullus of the suggestion, I tried to tack on world size but I have not solved anything, indeed, notable consumption of memory and moreover the displacement was not present on the whole shader.
I hope I misunderstood, and that the parameter to be changed is not this:
This isn’t a bug, it is a wanted feature to speed up performance. Corona calculates displacement only where the camera can see it. As the displacement is calculated before the reflection, the camera doesn’t know that it sees it (in that case in the mirror). This feature to speed up the performance has it’s limitations as we see in your example.
Hopefully we have the option to calculate only seen displacement and all displacement in the future.
Yes, thank you, I had guessed it, but I’m trying to figure out if this problem can be remedied.
For the moment I followed the suggestion of romullus but without result, I hope there is a solution to this problem.
Good morning beanzvision, I would not want to be wrong but I think it’s not your right example.
I understand that in the example tuom the part to reflect is all within the screen … or am I wrong?
@bango74: The solution mentioned by romullus is correct, and the “world space” setting shown by you is the right one. However 1cm may be to large according to your carpet, so try lowering the value.
NB - I’m a max-user and not a C4D-user, but I think this is the same in both packages.
Could you try to simplify your scene to isolate the problem, bango? Then we could all see if it is really the out-of-screen issue.
Also, the algorithm that decides if something is out of the camera view is only a heuristic, so it might behave differently based on the scene, camera properties, etc…
Try enabling the devel/debug mode (in Corona preferences) and then using this string option:
float geometry.displace.maxSizeScreenOutFrustumMultiplier = 1
