Problem DR, Crash parsing scene
HI!
Problems with DR, on a remote computer, the scene loads but closes when the status is Parsing. The scene separately on both computers is considered error-free.
Log DR:
2019-10-11 11:54:01 DR server started
2019-10-11 11:54:01 Binded to localhost
2019-10-11 11:54:01 Binding UDP socket to local address 192.168.137.1
2019-10-11 11:54:01 Binding UDP socket to local address 192.168.1.64
2019-10-11 11:54:01 Running Corona DrServer build Oct 3 2019 on TCP/UDP ports 19666, loopback TCP/UDP19667
2019-10-11 11:54:01 Available 3dsmax versions:
2019-10-11 11:54:01 2020: C:/Program Files/Autodesk/3ds Max 2020/
2019-10-11 11:54:01 2016: C:/Program Files/Autodesk/3ds Max 2016/
2019-10-11 11:54:01 Running command:
“C:\Program Files\Autodesk\3ds Max 2020\3dsmaxcmd.exe” “C:\Users\Feodor\AppData\Local\CoronaRenderer\DrData\corona_dr.max” -continueOnError -gammaCorrection:1 -rfw:1 -sf -v:5 -postRenderScript:“C:\Users\Feodor\AppData\Local\CoronaRenderer\DrData\post.ms”
2019-10-11 11:54:03 Started loopback connection with 3ds max
2019-10-11 11:54:04 Cannot contact 3ds Max, trying again …
2019-10-11 11:54:04 Started loopback connection with 3ds max
2019-10-11 11:54:05 Cannot contact 3ds Max, trying again …
2019-10-11 11:54:05 3dsMax started successfully
2019-10-11 11:54:06 Accepted remote connection from 192.168.1.66
2019-10-11 11:54:06 Started connection 1
2019-10-11 11:54:13 DR is finished
2019-10-11 11:54:13 Ready for new connection
2019-10-11 11:54:13 Accepted remote connection from 192.168.1.66
2019-10-11 11:54:13 Started connection 2
2019-10-11 11:54:17 Handshake: 0init1Max2020CoronaCamera0020 0 0 02560 1280834b5c66556f6e948d91c9c74c1b01d05 (DailyBuild Oct 3 2019)192.168.137.2
2019-10-11 11:54:17 Saving incoming scene to C:/Users/Feodor/AppData/Local/CoronaRenderer/DrData/received_scene_2314971674.max
2019-10-11 11:54:33 Downloaded scene: 175 M bytes in 15 s
2019-10-11 11:54:34 Render for connection 2 started
2019-10-11 11:54:36 Received sampling focus mask (region 0 0 2560 1280)
2019-10-11 11:55:39 Closing loopback manager
2019-10-11 11:55:40 DR is finished
There is a strange issue where this can occur with scenes which have locked cameras/views in the render setup dialog.
If you have a locked camera can you try to unlock it, select the camera/view you’d like to render and then relock it and save.
Let me know if this works for you.
Rowan
If I understand you correctly, this is not the case, the cameras are all unlock
:frowning:
What Rowmanns meant is the small “lock” icon in the Render Setup dialog. Just open it (F10), click that icon to unlock it, then select your camera view again, and then click the lock icon again. It sometimes helps in similar cases.
If it doesn’t help here, we will need full DR logs: https://coronarenderer.freshdesk.com/support/solutions/articles/12000002065
internal stuff
tickets/178733
