the export in vantage doesn’t work, I get this message,
Hi @vincenzo_ferrara ,
Can you please reproduce the error and send me the most recent V-Ray for Revit log file from C:\Users\<your username>\AppData\Roaming\Chaos Group\V-Ray for Revit 2024\Logs
You can email it to me at ana.lyubenova@chaos.com
A screenshot of the same error but with “Mostra detagli” expanded will also be useful.
Does the error also pop up when you attempt to render with V-Ray or it’s Vantage-specific?
- Ana
Dear @vincenzo_ferrara , hello.
Could you please confirm, Is the shown happening only with this specific specific scene.
Is it possible to Enable successfully V-Ray in a blank new scene?
Are you using the right e-mail address for logging to http://localhost:30304/#/ ?
Asking this because with the following domain @enzoferrara.it (used for your forum profile) no license information is found.
Waiting for your answer.
TS
The problem is present only with this file
It works well with other projects
Hi Vincenzo,
Please, in a freshly open project, reproduce the error, then navigate to C:\Users\<your username>\AppData\Roaming\Chaos Group\V-Ray for Revit 20xx\Logs and send us the most recently generated V-Ray for Revit .log file
Best,
Ana
P.S. Would be useful if you can also share the file with us ![]()
Hello again,
Feel free to send the logs and the scene via our contact form.
Please add this forum link in the description.
Thanks in advance.
Good morning,
I haven’t received a response yet, I urgently need to find a solution to the problem.
Hi vincenzo_ferrara,
As we already informed you once we received your scene, this is classified as a bug (REVIT-4440) and has been escalated to the Development team for further inspection and resolution. We will get back to you as soon as we have any updates.
