Problem file again
this file seems to crap out on all of a sudden…I did not change anything weird that I can think of…The file just will not do any prepass GI and a lot of erros like overbright materials , etc..etc…It was fine this morning and I need to fix this ASAP. Oh…and my vrlserver sometimes gives me application error when I open the file…click ok to cancel and cancel to debug…etc..etc
Thanx
And I can not even cancel out of the program now…GRRRRRRR…vray justs hangs…Or I mean Viz just hangs, but it does not say NOT RESPONDING or anything like that…
http://www.dbfinc.com/studio3d/downloads/firehouse.zip
JUst having a look at your file now.
As for the vrlserver.. maybe a memory problem? download memtest86 in ISO format and boot from that cd (after your burn it) and see if you get any errors after a complete test.
Ok,
The overbrights are cause by the architectural materials that you have. It says so right in the error logs :slight_smile:
[2006/Jul/25|11:14:43] warning: Material “Doors & Windows.Metal Doors & Frames.Steel Doors.Painted.White” (Architectural) is not compatible with V-Ray and may cause problems
[2006/Jul/25|11:14:43] warning: Material “Doors & Windows.Metal Doors & Frames.Aluminum Frame.Anodized.Dark Bronze.Satin” (Architectural) is not compatible with V-Ray and may cause problems
Fix those will be a great start, you also have a lot of standard max materials.. if possible converting them to vraymtl will help speed renders up a little.
Its not doing any prepasses because you have it loading from a saved IRmap file.
All seems fairly ok now :smile:
Ok…downloading the iso now…Damn desktop materials… lol… The file I sent was an older one and that one was loading from a ir map, but it crashes on the ir map…BUT…i found something…During an AERIAL view is when it crashes…But at a camera level…it is fine…weird…will make those changes and try again…Thanx …Get any new games lately…
Ahh ok… if its crashing it may very well be memory releated.
But try removing the arch materials… then convert all materials to vraymtl and then render again.
If it still crashes dump a grey vraymtl on all scene objects and see if it renders..
games… haha BF2… thats all ATM… cant stop playing :smile:
LOVE the BF2! Crazy addictive! hehe
:lol:
Totally agreed
