Problem in Particle flow _ Scale and Delete node
hi there
When I’m using delete and scale node in particle flow,simulating starts working and when it reaches to the frame which particles are supposed to be delete age or zero scaled,suddenly the process stops and after a while 3ds max crashes.
I tested in both 3ds 2017 and 2018.please let me know what the problem is.
Can you please send us a scene representing the issue?
Thank you,
thanks for the reply
Screen shot: delete and zero scale Particles in frame 37
Phoenix FD_Explosion_C_2017_01.zip (411 KB)
I couldn’t reproduce this crash, so my suggestion is to install the latest nightly build and try again with it.
Thanks!
I use the free version for one month, can not use the nightly build
Hey,
The screenshot does not really help - we need to equalize the sim settings with your scene when trying to reproduce the crash. If you can attach the actual scene, or send it to Support, this would be best. Otherwise it’s random guessing and this would likely not solve the problem.
Cheers!
