Hi guys,
here’s my problem:
I’m trying to set up a scene with following components: a mirror plane, sunlight and another plane (diffuse material). the sunlight should be reflected by the mirror plane und then illuminate the second plane. …but it doesn’t! other test objects are visible in the mirror (reflections) but light doesn’t seem to reflected!
here’s my setup:
vray version 01.05.29 (default render options)
sunlight (vray sunlight system)
mirror_plane (reflection layer added, reflection intensity white “255” (absolute reflective), reflection map: type none (absolute reflective) the preview looks perfekt mirror-like)
second plane (default vray meterial)
thanks for your help
