I miss clean selection masks for objects rendered with contour. So, the objects can’t be clean selected.
-Micha
Thank you for reporting this!
The issue is logged(ref VRW-3555). As a workaround please use the Contours RenderElement.
Hello, @Micha ,
The logged ticket was just revisited. The only solution available is to use Contour’s “Render Element Only” option. Enabling it prevents the toon contours from being baked into any other channels.
You will still be able to export the render output with contours by using VFB’s compositing tools - set the source to “Composite” and subtract the “Contour” render element from the image.
Kind regards,
Peter
