problem of memory
hello! i often have a problem with the amount of memory, especially in the final, telling me that there is not enough memory to do the denoising… i use an i9, with 64 gb of ram (ddr4)… Actually, there are no more “takes” on the motherboard to add memory…
it is, there by exeùmple, a rather simple scene, but rendered with a height of 9500 pixels… big, but nothing “monstrous”, like 12000 px… What do I need to do to make corona adapt to large image renders? Did I set the allocated memory wrong? (and if so, how to do it)… It’s a big problem for me, because I often do large format renders for my clients (advertising displays), and it’s a real handicap that this memory problem!! thank you for your advice!!!
Translated with DeepL Translator | World's Most Accurate Translator (free version)
ps:is there a way to uplaod a scene, even rather heavy?
and the pop up I have frequently!!!
You can upload files using the private uploader, or dropbox, see Chaos
For memory usage, less layers can help (e.g. LightSelects in particular), and be sure to be using 2.5D Displacement to optimize memory usage there. There is no memory allocation to set, Corona will always use as much memory as it needs (within what the system has available).
This might help too?
thank you for your answers! I’ve already use the tiled camera, when rendering BIG pictures with Physical render engine… But, does the tiled camera works with Corona??? I’ll try, it would be a solution!!
Yes, I have tried it myself and can confirm it does work. :smiley:
