Hi @klex167 . Providing a video would definitely help in at least showcasing the exact problem. It is important for us to know whether the materials do not show at all, or a wrong preview is being rendered.
Apart from that - you mentioned that you reinstalled Cinema 4D, but have you tried deleting its preferences directory? Also, if possible - can you try if you experience the same problem on different Cinema 4D version?
Also, it might be helpful if you share some additional information about your setup:
1. Hardware information - CPU thread count and available RAM.
2. Are you using a local Chaos license server or it is located remotely in your network. Can you try if borrowing your licenses helps? Can you check if you have alternative servers specified in your license settings?
Additionally, if none of the mentioned suggestions works, it would be helpful if you can enable the material preview logging and share the log with us - I will provide details on how to do this if the previous steps do not work.
I installed Cinema 2024 and VRay for 2024, but the same problem occurred.
Deleting the preferences didn’t work either.
I’m using a local license server, and after borrowing the license as you recommended, it suddenly works!!! Now all the material previews are displayed immediately.
Great, that we found the trouble maker, but can you give me some advise on how I can get the license server online working again?
Are you using the latest version of the Chaos License Server? And do you use a proxy or a VPN?
Usually, if borrowing the licenses to your local license server makes the preview work, it means that probably the connection between your local License Server and our Cloud license provider is quite slow or packets are lost. So I suggest investigating a bit more your internet connection.
Generally, I’m not well suited to help you with License Server problems, so I suggest if the troubles continue, to open a support ticket about this.
