Hi to all, I have had some problem whit the render-region.
When the render is finished, if I do a region, the old frame is deleted.
(I don’t change any parameter between full and region-render
I have noticed that it’s happening when I use much render elements.
Can you help me?
sorry for my poor language
Which V-Ray version is that?
If you have added a render element just before the region rendering then the VFB has been cleared.
Can you post simplified version of the scene to test here ?
Render Settings → Settings Tab → System Rollout → ‘Expert Mode’ → Previous Render - set to “Unchanged”
Turn off show Calc phase for Irradiance map or light cache.
