Problem Rendering Glare effect in high res - 3DS Max
I’ve created some great neon tubing in 3DSMax and rendered glare effect at low resolution however when I go to render much larger resolution I get no glare effect. Normally to render at very high resolution / size I would disable the memory frame buffer and render a v-ray raw image file. Apparently the memory buffer needs to be on for lense effects. Is this true? Any suggestions would be much appreciated. I need to render large enough for print reproduction.
Effects that depends on the VFB will not be applied in this case. You can render to a Vrimg or EXR file and then load the image back into the VFB to apply those effects and re-save the file. Furthermore you can free some memory up by resetting the 3DS Max application if the image resolution is quite big.
Thanks for your help Tashko. I’ll give that a try. I’ll let you know how it goes.
It Works!!! Thanks so much for your help. Made my day.
