hello
I would like to extract the green handle and its shadow on a well separated layer but I can not do it because it is inside a room and the shadows catcher does not work too well with you any idea?
thanks you so much
You can try this:
But I am not sure if this will give you the expected result anyway. I am guessing that the issue you are facing is that the shadowcatcher also catches the light bouncing around the room (the GI). On the other hand, if we would not catch the GI, then the result would look very different (for example the shadow is not 100% black because it is affected by the bouncing light).
