Problem - start C4D with CORONA
Hi guys!
I have problem with CORONA plugin in Cinema4D r15. I try instal Corona for C4D Alpha1.1.
Instalation without problems, but when I want to start C4D - here is warning message
Vstupní bod procedury
?colorAdaptationTransform@corona@@YA?AVAffineTm@1@MMW4CatSpace@1@@Z se nepodařilo v dynamicky propojované knihovně Corona_Release.dll nalézt.
—in translation—
Insert point procedure
?colorAdaptationTransform@corona@@YA?AVAffineTm@1@MMW4CatSpace@1@@Z couldnt be in dynamic connected bookcase Corona_Release.dll founded.
Do you think thats problem with instaled Vray ? Or how can i Fixed it ?
Thanks a lot for help.
It looks like mismatch between corona core and C4D plugin. Try deleting everything named “corona” from your C4D installation, and installing again fresh.
Thanks Keymaster, i dont have error massage but plugin is still not working.
I completly uninstall Cinema4D R15 … restart PC … and after install C4D … Corona Alpha1.1 / installation was OK … and as you see, everything from Corona plugin is in folders … but when I start Cinema4D R15 I cant see Corona in plugins or in RENDER settings … I dont understand why is not function ? Should I copy something from corona folder to somewhere ?
Thanks for reply.
you should still have corona in main menu (somewhere in About AFAIK), and it should say why it did not load
:frowning: i cant find About in C4D menu … or ? I found About in Help but there are only informations about C4D programers etc. I try find in script but nothing is there …
I tried copy CoronaMaterialConverter /plugin / to plugins and that plugin i found in menu → SCRIPT → PLUGIN MANAGER .. and that plugint dotn work too .. but CORONA plugin a cant see totally in C4D …
Because when i instal Vray plugin - i can see that plugin .. but I WOULD LIKE to work with CORONA …
I am looking in setting files - Corona and I compare it with file Vraykey .. and i think that problem will be with that
In Vraykey setting is setup - OPEN IN - WINDOWS SHELL COMMON
but in Corona files is setup - OPEN IN - UNKNOW APPLICATION
Im getting the same problem
Corona plugins (1.1 or 1.2)
dont work on install. ~ First time trying to use it.
