I have a problem with the installation of the Beta RC3 plugin with Cinema 4D R19. The installer seems to work correctly, I do a custom installation only for R19 (I have the R17 where I keep an old version of Corona Render), and the process ends without errors but when I go to the Cinema R19 plugin folder, there is no corona plugin. Did it happen to someone else? I use windows 10.
I manually installed the plugin folder and the files of the image editor (using the unpack file during installation), for the time being it seems to work.
Previously I had also tried to make a clean 4D R19 cinema installation and subsequently installed the plugin with the standard procedure, but the plugin folder was not written.
Now I try everything works for a few days.
